There is a engine removal / reinstall procedure that you can download from this site. I also used cardboard to keep the bolt locations identify...example is transmission bolts are various lengths. Just draw an outline of the transmission housing the push the bolts thru the cardboard at the appropriate location. Also one PITA was the accordian hoses. I would remove them before pulling and replacing the engine. Good Luck!
